Topic: Mixtrack Pro Compatibility and Support
Does anyone know if the first Numark Mixtrack Pro is supported by both Windows 10 and also Virtual DJ 2021? I ask because I am having issues VDJ detecting my Mixtrack Pro after upgrading my PC to windows 10. it's actually getting the mic to work that is the main issue
geposted Mon 01 Mar 21 @ 11:12 pm
Should be fine...
What is not working with the mic?
If you mean record/broadcast - the mic is not part of the USB audio, but goes straight to the speaker output of the controller. To be able to record/broadcast that you would need to loop the sound from the mixer output back into a line-in at computer, and set a "Record" entry in VirtualDJ equal to this line-in (called a "record loopback")
https://www.virtualdj.com/manuals/virtualdj/settings/audiosetup/recordloopback.html
geposted Mon 01 Mar 21 @ 11:13 pm
Thanks for your response.
The issue I have is that the MIxtrack pro does not even appear within the hardware section of the VDJ config.
geposted Tue 09 Mar 21 @ 9:44 pm
geposted Tue 09 Mar 21 @ 9:46 pm
