I have a problem with the cdj-3000 and virtual dj, after about 2 hrs of use aprox, the audio stop, the cdj, stop sending audio to the mixer o send butt the audio cut, very bad, the only way to fix, its turn off the cdj-3000 and turn on, again, buth the problems comes back after few minutes.
Computers: Macbook pro 13' ci7 and a new m1 chipset, same problems in both computers.
i
i
geposted Mon 08 Mar 21 @ 6:06 pm
Perhaps the hardware that failed?
Did you notice anything, like the lights fall out on the CDJ etc?
Could be a bad connection, power fluctuations etc..
Or did you notice/do anything in software that you think might have caused freeze/lock up etc?
geposted Mon 08 Mar 21 @ 6:43 pm
I dont think is the hardware, they are brand new, and the usb mode works perfectely, i think it is related with the use of memory related with the software and hardware
geposted Tue 09 Mar 21 @ 1:37 am
It looks like there might be a compatibility issue with pioneer gear and M1 macs.
I managed to reproduce the problem with the DJM-S11 on M1 mac, but on intel mac it runs fine.
geposted Tue 09 Mar 21 @ 12:09 pm
i think, i solve the problem, i update the firmware of the cdj-3000, and they are working fine now....
geposted Tue 09 Mar 21 @ 6:03 pm
Good good ;-) hopefully so
geposted Tue 09 Mar 21 @ 7:22 pm
