Hi,
Would like to see an option or feature to alternate EQ_low knob to BASS stem instead of KICK stem in the new stem modes ModernEQ, EZRemix and Full Stem
I rather use bassline transitions in my mixing and in genres kickdrums sounds equal anyway without a #key so that is seldom used
Using a DDJ-RR 2-channel mixer so Gain and Filter knobs overrides the stem feature
Try to do some mapping but it will make the controller that always perform a Bass Stem on EQ_low and options are unnecessary
Meanwhile, is it possible to change the coding for this manually? Can't find where
Thanx in advance
Thanx in advance
geposted Sat 13 Mar 21 @ 11:22 am
