Topic: Rane One echo effect
The echo effect doesn't work properly using the Rane One. The echo remains in memory after the trigger is disengaged. This means that the previous echo comes back on when the trigger is re-engaged adding unwanted previous echo sound to the next desired echo. The echo cuts off when you disengage the trigger. And continues where it cut off when re-engaged. It makes doing short successive echos impossible. The only way is to leave the triggers engaged and enable the echo with the fx on button. Maybe a script rewrite can solve this? All other effects work properly, only echo has this problem.
geposted Sun 14 Mar 21 @ 5:14 am
the paddle trigger effects are not post paddle(just like post fader). The effects turn off as when the paddles are disengaged and continues from where the previous echo stopped regardless of the song playing. Can someone look into this?
