As I can see this has been asked here some times, yet I dont get why this is not in VDJ yet.
I know automix will show me the length of the songs I put in, but if I have multiple playlists (which I do), then I need multiple steps to find out the length of each playlist.
So I wonder what is the reason NOT to show the total length of a playlist (virtual folder)?
For me it would help me a lot as I dont use VDJ to mix songs but to play them in the length they are. And I need to plan ahead with the total lenght of all of them.
So again, who would be hurt if you show the total length of a playlist just like you do in automix?
geposted Mon 15 Mar 21 @ 9:13 am
Can be shown in a few ways..
At your playlists click CTRL+A to select all the songs in the list, right-click and open tag edit.
Total duration of the playlist is shown at bottom
Generally speaking it perhaps for most users makes "less sense" to see length in a playlist view, since DJs mix the songs and hence its much shorter the mix of the songs than the total length of all songs combined
geposted Mon 15 Mar 21 @ 3:45 pm
Sounds like you're looking for some sort of radio automation software rather than DJ software.
Anyway all you need to do is ctrl+a and drag the tracks to the automix window to get the total time.
geposted Mon 15 Mar 21 @ 5:04 pm
"I know automix will show me the length of the song"
But thanks anyway.
But thanks anyway.
geposted Mon 15 Mar 21 @ 7:44 pm
Now THAT was a neat trick to learn, thank you!
I would like to see playlist length in browser window too. There is plenty of room in the status bar, right after where the number of files is shown. Which in itself is pretty useless, but the more the info the merrier so please do not consider removing the number of files :) I am currently looking at the playlist that says it has 27 files. Nothing can be decided from that number. But as your neat ctrl-a/Tag trick would tell me the playlist total duration is 03:11:14 which gives me indication that a 1.5h set can reasonably easily be played from that list.
Playlist duration in status bar would make lot of people (including myself) super happy.
geposted Mon 26 Apr 21 @ 3:22 pm
and by the way, if only 'will play at' was accessible
this field is unusable and inaccurate (never update/refresh and inaccessible)
bottom will play at + length - top will play at would give the total time
geposted Mon 26 Apr 21 @ 3:46 pm
'Will play at' takes automix settings into account, so it's not exactly the same as sum of length.
geposted Mon 26 Apr 21 @ 4:09 pm
So if there has already been a calculation that has taken place then what is the issue with displaying the overall time left at the top of the column?
Not something I really use but there have been many requests for this over the years.
geposted Mon 26 Apr 21 @ 4:13 pm
I agree that having the playlist length beside the number of files would be extremely useful. Mixxx has this. The number of files is not a very significant piece of information, but how long the playlist would run is certainly useful.
geposted Sat 09 Jul 22 @ 12:40 am
hello..does anyone how-to show the number of tracks on the side list....it did at one time but not now for me ..please help
geposted Sun 10 Nov 24 @ 6:40 pm
If you mean the automix list it tells you automatically.
geposted Sun 10 Nov 24 @ 7:22 pm
@mhales mouse over the text in the header.
geposted Sun 10 Nov 24 @ 7:25 pm
