In the deck information tab, I'll like to see information from the album and the comment tabs instead of the remix and feat. tab in the performance skin. Now for the remix tab, I've tried changing the "get_remix" to the "get_album" and replace "remix" with "album" however, the deck display info tab was blank. I'm not sure about the feat tab...
geposted Mon 15 Mar 21 @ 10:04 pm
"replace remix with album " is just for the skins text color, so leave that be... 'remix' there just refers to a color value defined earlier in the skin .. (color="remix" => <define color="remix" value="#9b9b9b"/> earlier in skin )
action="get_album" should work fine though, for as long as the song actually has album tag
geposted Mon 15 Mar 21 @ 10:13 pm
Thanks... However, it didn't work. more changes were needed.
Wrong
<text fontsize="18" color="title" weight="bold" action="get_title_before_remix" important="true"/>
<text fontsize="18" color="remix" action="get_album_after_title" important="true"/>
Correct
<text fontsize="18" color="title" weight="bold" action="get_title" important="true"/>
<text fontsize="18" color="album" action="get_album" important="true"/>
The only question I have now is can I space them out...
geposted Mon 15 Mar 21 @ 11:18 pm
as it seems you are in a grouping textzone (group='horizontal")
just add a separator in between
always appears:
pre-defined by parameter:
or just a custom text when needed
there are many other possibilities specially to append / prepend with the same color as title or album
or using format instead of action or param_add with text
always appears:
<text fontsize="18" color="whatever" text=" - sep - " important="true"/>
<text fontsize="18" color="whatever" action="get_artist_title_separator" important="true"/>
<text fontsize="18" color="whatever" action="get_album & not param_equal '' ? get_text '***' " important="true"/>
geposted Mon 15 Mar 21 @ 11:43 pm
Knightrin wrote :
Correct
Correct
there is no color="album" .. unless you defined yourself
Keep color="remix" . This part is purely made up syntax. It could as well be color="green" or color="mycolor". So there is no logic in changing remix to album there ... Unless you also defined earlier in skin what color="album" should mean/refer to ...
But yes, its get_album, not get_album_after_title, so that part is all good ;-)
For simplicity just add some text line to add space or other logic..
<text fontsize="18" color="remix" text=" ( " important="true"/>
<text fontsize="18" color="remix" action="get_album" important="true"/>
<text fontsize="18" color="remix" text=" ) " important="true"/>
For example ;-)
geposted Mon 15 Mar 21 @ 11:49 pm
and by the way if it's for having both the separator and the same color all the time
one line will do
<text fontsize="18" color="remix" format=" ( `get_album` ) `" important="true"/>
one line will do
geposted Tue 16 Mar 21 @ 12:12 am
For example ;-)
Knightrin wrote :
Correct
Correct
For example ;-)
BOOM!!! It works thanks...
geposted Tue 16 Mar 21 @ 12:45 am
always appears:
always appears:
I like this option better...
Thanks For You Guys!!!
geposted Tue 16 Mar 21 @ 1:03 am
So the next thing is if possible to also add the comment section in the deck info?
geposted Tue 16 Mar 21 @ 1:05 am
Can do that same way, but with action="get_comment"
geposted Tue 16 Mar 21 @ 1:07 am
it looks you used textually color="whatever" ^^
this is the same as previously... it does not exist unless you defined one
currently stars are written anyway but in default black color
geposted Tue 16 Mar 21 @ 1:19 am
Yes, sorry... I did change that code...
<text fontsize="18" color="remix" action="get_album & not param_equal '' ? get_text ' ' " important="true"/>
geposted Tue 16 Mar 21 @ 1:53 am
BOOM!!! Thanks... It worked...
<text fontsize="18" color="remix" action="get_comment & not param_equal '' ? get_text ' ' " important="true"/>
<text fontsize="18" color="remix" action="get_comment" important="true"/>
geposted Tue 16 Mar 21 @ 1:55 am
