Hello,
I've read the FAQ article on how to transfer VirtualDJ 8 to a new Computer(https://www.virtualdj.com/wiki/How%20to%20Transfer%20To%20A%20New%20Computer.html)
I tried the steps there but none of my settings or cue points were transferred correctly.
The first bullet point in the article says "Copy your music collection into the internal Hard Drive of your new computer to EXACTLY the same location with the same folder structure"
I used an external hard drive on my old computer to access my music with VDJ. My new laptop has a bigger hard drive, so i just copied my music folder into the music library on it. Is this why none of my settings transferred over? Would I have to create a partition on my new laptop's hard drive to mimic exactly how it was setup on my old computer?
geposted Wed 17 Mar 21 @ 8:59 am
You should move the files from the external drive to the laptop internal drive from within VDJ (right click, file operations, move or copy to) and it will move the database entries for those files over too.
For external drives the database is kept on that drive, not the PC itself. That's why the track info has not been carried over.
geposted Wed 17 Mar 21 @ 9:09 am
Could I do that from my old computer instead, and then just redo the transfer process?
geposted Wed 17 Mar 21 @ 9:15 am
Only if there's enough space on your old computer for all the files.
geposted Wed 17 Mar 21 @ 9:21 am
This worked!!! THANK YOU!
geposted Wed 17 Mar 21 @ 9:46 am
No problem, glad you're sorted!
geposted Wed 17 Mar 21 @ 9:49 am
