Forum: Addons
Topic: Vocal FX
geposted Sat 20 Mar 21 @ 10:18 am
Hey, I like this effect, what can i do to turn on the effect when I press the button just once. Deactivate it by pressing it again, Same for light, Turn it on the button light when pressing the button and turn it off when deactivating the effect. Than you.
geposted Sat 20 Aug 22 @ 9:14 pm
Also, after I use the effects Echo, I wont be able to use the normal echo effect,
geposted Mon 22 Aug 22 @ 7:08 pm
ChaksiPRO InfinityMember since 2011
Hi there, did you find a solution to your enquiry? I am also interested in figuring out how to toggle the effect on and off with LED feedback as well.
geposted Mon 12 Dec 22 @ 8:44 pm
Is there a way to change it to toggle On/Off?
geposted yesterday @ 10:09 pm
It's a padpage all the script is available there to read and adapt.
geposted yesterday @ 11:04 pm
