Topic: VDJ not loading
I just downloaded VDJ to my MAC and it won't open. It says it opened but won't show on screen.
geposted Sun 28 Mar 21 @ 6:25 pm
First try restart the mac, in case of some frozen process.
And if still no luck, try delete settings.xml in /documents/virtualdj/ then start the software.
And also, looks like you are on an extremely old macOS, would be worth upgrading ;-)
