Since upgrading to latest VDJ, I've not been able to get my Yeti mic to work. Been through the configuration settings. Am I missing something? Thanks.
geposted Mon 29 Mar 21 @ 3:34 am
Since you mentioned updating can you confirm your audio configuration? Config>Audio should display an input set up to use your microphone. https://virtualdj.com/manuals/virtualdj/settings/audiosetup/microphone.html
If that does not work close out of virtual dj and test the microphone with another app or by using the OS's audio preferences.
If there has also been a recent update of the OS, windows recently had one, you may have to download and reinstall the drivers for that device first. Make sure to reboot and that nothing else is using that microphone input exclusively.
geposted Mon 29 Mar 21 @ 1:02 pm
Please post a screenshot of your VirtualDJ Audio setup
geposted Mon 29 Mar 21 @ 6:10 pm
Cheers, I'll have another go
geposted Mon 29 Mar 21 @ 9:39 pm
Many thanks for your replies. After testing my Yeti on different ports on my laptop, including PC, I realise it's time for a new mic. Cheers.
geposted Wed 31 Mar 21 @ 8:46 pm
