Topic: Virtual DJ already running
i just paid just now the virtual dj software...now when trying to open the software i keep getting the message" virtual dy already running
uninstalled previous versions and re installed w same message : 'virtual dj already running"
geposted Wed 31 Mar 21 @ 12:57 am
check taskmanger see if a vdj process is running, if so kill it
geposted Wed 31 Mar 21 @ 1:08 am
proleme data basse
geposted Tue 17 Oct 23 @ 10:50 am
I'm having a similar issue but mine occuras 50-60% of the time when I try to open it. Even at this moment I have it on my Taskbar and have clicked it to open it. Nothing happens however. If I try to open it again it just pops up the prompt "Virtual DJ is already Running" but I am unable to see or access it in any way. I have restarted my computer in past times and that has occasionally helped but not always. SOmetimes after an indeterminate amount of time it will open but not in any way that would be expected of a normal working program
geposted Sat 23 Mar 24 @ 8:46 pm
Are you using a PC? For some reason I regularly find multiple copies of VirtualDJ running in Task Manager. It just doesn't seem to like shutting down cleanly.
I'd suggest checking there, because they don't show up any other way.
geposted Sat 23 Mar 24 @ 9:13 pm
djcelPRO InfinityModeratorMember since 2004
Do you use ASIO, a controller, video, stems when it happens?
geposted Sat 23 Mar 24 @ 9:35 pm
Who are you asking?
geposted Sat 23 Mar 24 @ 10:15 pm
