Topic: Numark M6
sangpukHome userMember since 2020
Can i use this mixer without lisence? Can't find this one in the list...
please some other recommendations on home use VDJ compatible mixers (no jogwheels) for a maximum price of 300 $
Thanks!!!
geposted Thu 08 Apr 21 @ 9:47 am
that isn't a midi device, and only has 1 stereo usb channel in. So doesn't really qualify as a software djing device.
There is no free use with hardware, sending midi or multiple usb stereo channels, as you would need to dj, requires a licence.
geposted Thu 08 Apr 21 @ 10:02 am
You can use the mixer with a soundcard that has 2 stereo outputs (one stereo output per deck)
And then connect this to separate channels on the mixer, and mix analog on the mixer itself
Additional software features you would then have to control on the computer itself.
But a very common setup, even more so back in the days when there where few midi controllers around, and clubs/gigs for sure never had such. Works fine for transitional djing ;-)
(you need an External analog mixer license to be able to use, either Home Plus with this specific license, or Pro license that works with "any" setup)
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/externalmixer.html
geposted Thu 08 Apr 21 @ 10:50 am
geposted Thu 08 Apr 21 @ 6:21 pm
