Would like to see a preset auto loop feature to turn on by itself when it reaches a certain part of a song without worrying about hitting the loop button on the fly at the break. It's already pre-set in the song.
Also, would like to see if you can just place a starting and ending marker or cue points to edit a song faster. Would like the cut method in track cleaner to shorten up the song or select a block of audio then move into a new position with some type of marker, instead of dragging the mouse in the editor.
DJ-Insane512
DJ-Insane512
geposted Sat 10 Apr 21 @ 6:29 am
http://www.virtualdj.com/manuals/virtualdj/editors/poieditor.html
easy with action poi, call a loop, jump from one position to a hotcue.
geposted Sat 10 Apr 21 @ 11:17 am
