HIE EVERYONE
its a pleasure to be on this forum.How can i create my own samplers or sound effects on Virtualdj?Secondly which sites can i download new trending sound effects or samplers?
Thirdly why do my recordings skip or jump when i playback after recording a set?
Lastly what device do i need to connect so i can record my own voice in a home setup.Laptop only?
Thank you in advance.
geposted Fri 16 Apr 21 @ 10:56 pm
I guess "sound effects" you mean as samples...
You can download more from within the software, if you open settings, and look under Extensions
https://www.virtualdj.com/wiki/how%20to%20install%20plugins%20and%20addons.html
You can also create your own sound samples easily by recording a loop from any favorite song etc.
And if you google "sample packs" you find 1000s of sites where you can downloads.
Such samples downloaded you can just drag and drop to sample banks in VirtualDJ to use
Short sampler basics tutorial:
http://www.virtualdj.com/help/videotutorials.html?view=quicktips&episode=sampler
How to record and create your own samples:
http://www.virtualdj.com/help/videotutorials.html?view=quicktips&episode=samplerrecord
geposted Fri 16 Apr 21 @ 11:17 pm
As for why recording skips, might be too slow hard-drive or computer.
Try record in mp3, and can try set bitrate lower as well in settings. Search record in VDJ settings
To record your voice, you need a usb mic or use your laptop built in mic if it has (might not be best quality, but can do for a "shout out" in the mix etc)
How to use mic see here:
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/microphone.html
geposted Fri 16 Apr 21 @ 11:20 pm
Your response has been priceless bro.Thank you very much Truly appreciated.More questions will come as i explore more about this interesting software.
geposted Sat 17 Apr 21 @ 7:49 pm
