Currently, it's impossible to satisfactorily prepare songs for Karaoke using Virtual DJ:
I propose to improve parsing of LRC files, according to all existing standards.
If you request, I may provide you with a simple parser class for free. Or even a WPF control utilizing that class. Just ask.
Thanks.
Thanks.
geposted Sun 18 Apr 21 @ 2:05 pm
Do you have any link to a full specification of the LRC file format?
I cannot find any mention of double time tags
geposted Sun 18 Apr 21 @ 2:34 pm
I can confirm this bug.
When the lrc-file is a companion file to the video and is played as karaoke, then the alignment of the lyric-text is fine.
When i use the video editor and i insert the same lrc-file as karaoke overlay (German:TEXT ÜBERLAGERN) the synced lyric-text is misaligned after saving as .vdjedit-file.
Most of my lrc-files are handcrafted and aligned with LRC-Lyricist, which is a very handy tool and it also works with mp4 videos.
Videos are often longer than the Song as audio-file. So i have to re-align the lyrics for the video manually.
geposted Tue 20 Apr 21 @ 8:59 pm
We have found the issue when using float up in the video editor. Will be fixed in the next update
geposted Wed 21 Apr 21 @ 3:23 am
Just tested with a few lrc-lyrics in Videoeditor (build 6418 VDJ 2020 and VDJ 2021).
Now the lyric-text is perfect aligned with the video in the .vdjedit-file.
Also the charset is ok for me (tested with ESC-Chars ' and german umlauts äöüß).
Best Greets to the team - good job
geposted Thu 22 Apr 21 @ 8:46 am
