Hi, turned on vdj 21 today after using last night and and have done for 12 yrs, and all the settings, including que points, controller settings, basically everything have disappeared.....totally gone! Apart from the music, it started up like a new install. It's not the laptop, unless anyone can suggest why. Fed up is an understatement. Any advise.
Win 10
Asus is
16 gig ram
Latest vdj build, updated the other day.
Win 10
Asus is
16 gig ram
geposted Sat 01 May 21 @ 1:34 pm
Usually it's a dead previous process locking the database.xml file and settings.xml file
In that case a simple laptop reboot fixes the problem
geposted Sat 01 May 21 @ 2:53 pm
No its doesn't on this occasion, but then you read my fb page about it too, so you would know. Im after answers to a problem not your assumptions, and I mean that in a nice way.
geposted Sat 01 May 21 @ 3:15 pm
