Topic: Clear Deezer tracks
I haven't used Deezer for 6 months but still find Deezer played songs in search. Can all Deezer songs be removed as probably won't subscribe again..
geposted Sun 02 May 21 @ 4:17 pm
What do you mean by search?
Is it when you look for a song or is it your history files?
geposted Sun 02 May 21 @ 4:34 pm
When I type in search box still keep finding Deezer songs from last year
geposted Sun 02 May 21 @ 4:40 pm
Click the button to the right of the search bar and untick "search online catalogs"
geposted Sun 02 May 21 @ 4:46 pm
Can also right-click the Deezer folder, and "sign out" if you intend to use it no more
geposted Sun 02 May 21 @ 4:48 pm
Search online catalogs was unticked it's just showing previously played from Deezer.
And signed out Deezer now
geposted Sun 02 May 21 @ 4:53 pm
Create a filter folder with the action:
file type contains "deezer"
(or file path = "deezer")
Then click CTRL+A to select all the result, and right-click selection choose batch => remove from search db
(Although logging out might have been plenty... )
geposted Sun 02 May 21 @ 7:30 pm
All the Deezers removed. Typed DZ in search and went down and deleted, found a few soundclouds as well haven't used that for long time and wasn't logged in
geposted Sun 02 May 21 @ 9:12 pm
Tusen takk Rune!
geposted Sun 07 May 23 @ 6:52 pm
