Right side started rotating to the left. Couldn't stop it. Had to reboot..happened again..any clue?
geposted Sun 09 May 21 @ 3:37 pm
do you have anything mapped to -> dump : reverse the playback direction while dump is active, then when deactivated, start again forward from where the song should have been if it had been playing forward during the dump.
maybe an action POI that didn't get deactivated to censor bad words?
you can map any button to dump and it should toggle it for the active deck
geposted Sun 09 May 21 @ 4:10 pm
