Hello, I feel like I have, probably a very simple question, that I cant for the life of me figure out....
When I'm playing a music video on the left deck and load one up on the right deck, I simply want to be able to press the play button on the right deck and have the video AND audio crossfade go from 100% left to 100% right, automatically. And then back again if I press play on the left deck.
I've had this work before and when I updated to Virtual DJ 2021 the settings changed and I cant figure out how to replicate it.
THanks
THanks
geposted Mon 10 May 21 @ 4:54 pm
Its possible to do..
But perhaps the more common way is fader start. (faderStart in settings)
In other words, as soon as you crossfade over from deck A to deck B, deck B starts to play automatically
geposted Mon 10 May 21 @ 4:59 pm
by default this is the stop button/level audible that enable the crossfader
faderStart using the crossfader needs level to be set to audible BEFORE to load the track
(otherwhise the level button will do the job)
If you really want to use the play button: you can map to play & auto_crossfade
taking care of the sync between play & crossfader
(can easily swap, specially with 4 decks and automix dualdeck)
geposted Mon 10 May 21 @ 5:57 pm
Crossfader starts the song instantly,. works fine..
can also use level faders
geposted Mon 10 May 21 @ 6:07 pm
