SALUDOS
ME GUSTARIA ADQUIRIR LA LICENCIA ~INFINITY~ , SIN DUDA ES LA MEJOR OPCION PARA MI...
MI PREGUNTA ES, PARA CUANTOS EQUIPOS PUEDO UTILIZAR LA MISMA LICENCIA
SOY NUEVO EN ESTE TEMA DE LICENCIAS, POR SU ATENCION, GRACIAS DE ANTEMANO
geposted Wed 19 May 21 @ 10:48 pm
With the infinity license there are no limitations..
You can use as many controllers and mixers as you want ;-)
(max 2 computers at same time... )
geposted Wed 19 May 21 @ 10:55 pm
Saludos
Agradezco tu atención
Estoy en búsqueda de una licencia en donde pueda utilizar varios ordenadores al momento.
Cual me puede aconsejar
geposted Wed 19 May 21 @ 11:36 pm
How many computers?
The Infinity license allows your main computer, plus backup computer, to be used at same time ...
You want more than that?
geposted Thu 20 May 21 @ 9:28 am
