Hello guys,
Can somebody tell me the command that change the level of an active effect (Echo, Reverb, Flanger)? Because I have Numark Party Mix and I want to set a knob with this command.
geposted Tue 25 May 21 @ 5:07 pm
effect_slider 1 1
[slot 1 slider 1]
effect_slider 'echo' 1
[specific to echo]
effect_slider 'echo' 1 & effect_slider 'flanger' 1
[two sliders at once]
[slot 1 slider 1]
[specific to echo]
geposted Tue 25 May 21 @ 5:20 pm
And how can I set to change the level of an effect just for the active deck?
geposted Tue 25 May 21 @ 6:22 pm
deck active effect_slider 1 1
Or probably better:
deck playing effect_slider 1 1
Or probably better:
geposted Tue 25 May 21 @ 6:33 pm
pretty sure not what is expected even it often matches :
"deck active" refers to the most audible deck (level and crossfader) when selected deck (with focus) is "deck default"
deck default effect_slider 1
geposted Tue 25 May 21 @ 6:42 pm
you probably want active deck though...
geposted Tue 25 May 21 @ 6:49 pm
