As a Fruit skin user I try to change the mixerOrder from 1,2,3,4 to 3124, but unfortunately the mixer order doesn't change. Even if I want to adjust the mixerOrder of the default skin, that doesn't work and remains rock solid at 3,1,2,4. The change will take place in settings.xml. Who can offer me the solution.
Thanks in advance.
W10, v8.5-64 b6444, no controller
Thanks in advance.
geposted Wed 26 May 21 @ 4:20 am
Unfortunately, the latest update (b6477) did not offer any improvement for me. I hope it is the intention that a change to the mixerOrder setting will also be visible in the skin, if not I'd like to hear about it.
geposted Fri 28 May 21 @ 4:15 am
Will add to default..
Why it doesnt work on other skins, not sure..
Its fairly uncommon that mixer order is other than 3124 though, so maybe noone used that in the other skin ;-)
geposted Fri 28 May 21 @ 7:51 am
I understand that in settings "mixerOrder" makes no sense because mixerOrder has a default value and therefore cannot be manipulated. With me, the default (pro) skin is also not manipulable.
Incidentally, it has worked well, but is already a while ago.
geposted Sat 29 May 21 @ 6:12 am
