Hi all, I'm using the TMmania 3 Decks Skin, with no current issues I might add. Although it has been suggested that I reach out to DJDad about updating the script and logic. As it was suggested on the Facebook official Virtual DJ Support Group page 'There's basically no way of knowing when a minor change in the current script engine will break it.
So if your out there DJDad please drop me a message.
geposted Tue 01 Jun 21 @ 7:28 am
TCMania skins were made years ago for version 7. Even though they should "work" with version 8, there is no plan for updates.
geposted Tue 01 Jun 21 @ 8:52 am
Thanks for your reply DJDAD.
So you think it should be OK then. In truth I have never had an issue with it. I only reached out on the advice of comments on the FB VDJ support page. It's a great skin and using 3 decks as I do it really makes the VDJ experience much better than having to have the VDJ 4 deck skin. I'm not sure if you produced it, but if so great job in accomodating us odd balls who are into un-even numbers of decks.
geposted Fri 04 Jun 21 @ 11:05 am
