hello, i have a bluetooth headphones, to have the pre-listen in the headphones should i buy a external audio card? Many thanks
geposted Tue 01 Jun 21 @ 8:16 pm
if your computer have bt no need of audio
unless you want to sync tracks, in which case bt latency may be an issue
you can deal with it or
depending on computer / laptop you may use other existing audio device
front + rear jacks or jack + hdmi
if none is available then yes you need extra audio card/dongle
geposted Tue 01 Jun 21 @ 9:31 pm
