I am trying to figure the correct settings for stems. I want VDJ to always compute the stems when the song is loaded and then either remove the stem file when the song is removed from the deck OR remove all stem files when shutting down the software.
What would be the recommended options for this behavior?
Thanks
Thanks
geposted Sat 12 Jun 21 @ 2:28 pm
try config/option and type stems.
geposted Sat 12 Jun 21 @ 2:35 pm
I don't think either of those options exist at present.
There's a command - Database - remove all precompued stem files. Can't find a direct command for it or you could set that to onexit.
geposted Sat 12 Jun 21 @ 2:53 pm
Just the default will compute on load and not save any files, isn't that what you want then?
geposted Sat 12 Jun 21 @ 3:17 pm
By mistake I chose to save prepared stems on over 30K songs. Is there any way to stop this ? I only want stems to be prepared when I load the song. Thanks in advance
geposted Thu 09 Mar 23 @ 1:26 pm
Delete the tasks.xml file from the VDJ folder when the program is closed.
geposted Thu 09 Mar 23 @ 1:44 pm
Or right-click the Stems folder and select cancel
geposted Thu 09 Mar 23 @ 2:29 pm
Thanks very much !!! Clicking on the Stems folder and cancelling worked like a charm
geposted Fri 10 Mar 23 @ 12:28 am
