Hi everyone, fairly new to virtual dj. I was able to connect my ddj sx3 to virtual dj and get the essential buttons working (cross fader, volume fader, play/pause, etc) but there are some buttons that do not do their intended function. Some do nothing when selected and others perform actions that the button is not meant for. Is there a way to import a skin that functions better with my deck or is my best bet to map out all the buttons that don’t work properly? Thanks!
geposted Tue 15 Jun 21 @ 4:50 am
It's not the skin, it's a common early misconception, the skin is just a visual and what the mouse interacts with, you want to change the mapping [how the controller talks with vdj]
What is you want to change?
geposted Tue 15 Jun 21 @ 6:45 am
I believe it's only the Flip buttons that are left un-mapped. All others should work as described in manual https://www.virtualdj.com/manuals/hardware/pioneer/ddjsx3/index.html
Ask here what you want to change with what and we will provide further instructions
geposted Tue 15 Jun 21 @ 1:28 pm
