Option to turn off column resort. I built a track list for a set I'm performing in three hours, and one misclick of a header and the entire playlist is out of order. Worked on it for 4 hours, and one click is enough to mess it up. BAD DESIGN. Needs to have the option to at least turn that off.
geposted Sat 19 Jun 21 @ 10:32 pm
if using latest EA :
activate column "Order" in playlist by right click on column headers and sort using this column
if not :
you may reset sort order from playlist the same menu
if not :
geposted Sat 19 Jun 21 @ 10:54 pm
