1. I prepare some music to play by putting it first without the order in Sidelist. I drag files from my disk folders on the left pane to Sidelist on the right pane. Then I open Sidelist in left pane and drag songs in proper order to Automix pane. Unfortunately a file added to Sidelist in the right pane doesn't show in Sidelist in the left pane (Lists & Advice/Playlists/Sidelist). I found that the only way to refresh a list on the left is to restart the software. Is there any other way to refresh lists on the left?
2. Is it possible to move (not copy!) songs from the Sidelist to AutoMix list? I want them to disappear from the Sidelist so I don't add the twice to list in Automix for the party.
3. Is there any way to search in the right pane? It's so needful! I add songs to Automix and there is no way to check if I don't double them.
geposted Fri 25 Jun 21 @ 11:29 pm
