Hi Everyone, I wanted to get your insight on recommended settings for live streaming on Mixcloud. Most recently, my live streams were ended prematurely, and I could not re connect to the same stream as it thought I had ended the stream myself, of course I didn't. I had to go to the Live Stream Details and add part 2 and or change the name to get the stream to connect again. This is frustrating because this has happened twice in the last month while I was building my audience following. I do not use OBS, I use the direct connection from the VDJ dropdown, I am wired / 236 Mbps / 11Mbps / Video Broadcast = Low / I use Audio and Video on my livestream and I also use Shader & Slideshow / Laptop - HP Envy i7 1.80 Ghz 1.99 Ghz 64 bit/ VDJ Version V8.5-64 b6541 . I tried asking the Mixcloud community but I do not believe there is a support page or forum to ask these troubleshooting questions. Thank you all in advance.
geposted Fri 02 Jul 21 @ 11:46 pm
