So I finally have a laptop capable of supporting stems without having to precompute everything. So I have 2 requests. I apologize if the features already exist as I haven't found them yet. I have precompute set to manual.
1. On some of the songs I load (it does the stem analysis on load), even after shutting down VDJ and restarting the computer, the .vdjstem file is still there. Can we set it up to delete those files on shutdown instead of having to do it manually through the menu?
2. Can we add a setting to exclude certain directories (i.e. d:\karaoke) or file types (i.e. *.zip) from being analyzed?
Thanks in advance! Love being able to use the new feature, just trying to automate having to turn it on and off.
geposted Mon 12 Jul 21 @ 1:40 am
If you set 'precomputeStems' to manual, then no .vdjstems will be created (and thus no files need to be removed either)
Since you say your laptop supports stems without problems now, what is the issue exactly?
geposted Mon 12 Jul 21 @ 7:24 am
