ok i am absolutely useless at sorting or modding a skin ,so is there anybody out there that can help??
ok i have 2 dell windows tablets (i5s)that i want to use with vdj but i want the new vdj skin modded so it shows only 1 deck per tablet (vdj VirtualDJ 2021 b6613 PC) as i don't use for anything other than home personal use (having retired many many years ago)
can anyone mod the new VirtualDJ 2021 b6613 PC skin to do that for me???
can contact me though here
thanks in advance
thanks in advance
geposted Thu 02 Sep 21 @ 7:16 pm
I did this split of elements with the skin "oldSchool by Zanard" adding missing features
each element being in its own window (decks, mixer, browser, pads, videos ...)
this was for use with 2 additional touch screens (one per deck and one for mixer or more)
not so simple to create and to configure, but really fine to use once done
https://imgur.com/a/NZsYvwt
due to internal structure of default skin , it would be a real hard job for this one ^^
with 2 tablets, i think it would be more usable if one is used an extra monitor for the other using software such as "Spacedesk" or other desktop extender
geposted Fri 03 Sep 21 @ 5:20 am
It's not too difficult to add extra floating decks windows to default:/pro layout
i.e.: QnD simple version of autonomous extra floating decks
can be added i.e.: in DECKS section after normal decks line 4770
use some custom buttons "show_window deck1" "show_window deck2" "show_window deck3" "show_window deck4" in a way to make then [dis]appear
<window class="deckleft" name="deck1" deck="1" color="background" visibility="not deck 3 leftdeck"/>can be used as a start point
<window class="deckleft" name="deck3" deck="3" color="background" visibility="deck 3 leftdeck"/>
<window class="deckright" name="deck2" deck="2" color="background" width="799" visibility="not deck 4 rightdeck"/>
<window class="deckright" name="deck4" deck="4" color="background" width="799" visibility="deck 4 rightdeck"/>
geposted Fri 03 Sep 21 @ 7:42 am
That's pretty helpful thanks!
geposted Sat 11 Sep 21 @ 6:06 pm
a fix in new EA 6636 allow now decks located left of main window do receive drag&drop with skin display visible
geposted Sat 11 Sep 21 @ 6:16 pm
