Forum: VirtualDJ Plugins
Topic: Add a textbox in effect panel
Hello. I am trying to make a broadcast message adder addon (like RDS) for VirtualDJ (also I am gonna upload it, I hope it will get approved) and I want to add a textbox in the effect panel. How can I do that ?
geposted Sat 11 Sep 21 @ 5:50 pm
to display text you can use string parameter type VDJPARAM_STRING in DeclareParameter()
you can use a variable set using set_var_dialog script using GetInfo()
Then either send it to plugin string or command
or read it from plugin using GetStringInfo()
take care that set_var_dialog script detach from script chain
maybe unexposed yet feature exists in recent API additions
