Trying to find some help not good with all this but what I'm trying to do is change the color of the default skin when a song is highlighted in the browser. Right now it's a soft Gray with my vision I can lose my place very easily. Trying to change it to a light blue like in the picture is this possible.
geposted Wed 22 Sep 21 @ 6:42 pm
geposted Wed 22 Sep 21 @ 7:00 pm
If it's just one color , then you can manually edit the xml of the skin.
If it's the Pro default, you will find 3 lines defining the color (one for each color theme).. e.g.
<define color="browseroverfocus" value="#4b4c4d"/>
Change the value pointing to a new html color value .. e.g. #4A8EC2
If not the default, then you ll have to tell us which skin that is, to guide u further.
geposted Wed 22 Sep 21 @ 7:01 pm
The skin is the Pro default skin on performance. I don't see a xml for
this skin.
this skin.
geposted Wed 22 Sep 21 @ 10:07 pm
this skin.
this skin.
open VDJ, open the options menu, all the way to the left click on interface, click on your skin,top right corner click edit this skin. and there is your answer sir...i tell djs all the tyme just open up VDJ and look around, click on menus, click on dropdown arrows. basically just look around and learn the software you paid for.. its how ive learned all i know about vdj but looking around in the software
geposted Wed 22 Sep 21 @ 10:38 pm
Thank you all I was able to get this done. djtyme209 you are so right but I guess I'm old school I went to the skin folders and did not see anything I guess there is always something new to learn. But that's why I love this form it's always someone that can help.
Thanks Again
Thanks Again
geposted Thu 23 Sep 21 @ 3:05 pm
Thanks Again
Thanks Again
no problem sir :-) and i like that new highlighted color
geposted Fri 24 Sep 21 @ 2:19 am
