fresh install or re-install?
I was having difficulty with virtual dj 1.06 and HT compatibility. I was getting the typical screen corruptions, etc. So I have to set the program to Win 98 emulation to get it to work properly.
I did an uninstall and a new install of 1.07 so I could change the program compatibility settings. Was this a wise thing to do, or should I have installed over the previous version? I now have 1.07 with no emulation ,but running under full XP settings.
Have the issues been resolved?
Thanks,
Ronny582
Thanks,
Ronny582
geposted Tue 11 Nov 03 @ 3:40 pm
The HT problem should now be fixed. But before posting it in the history, we prefer to get some feedback from users.
geposted Tue 11 Nov 03 @ 3:51 pm
HT problem isn't fixed yet totally in 1.07b, graphics still mess up exactly like before, but it seems when i got gfx messed in 1.06 in couple seconds of resizing file explorer window, now it takes maybe 5 or more seconds of resizing the playlist-file-explorer window.
geposted Sat 15 Nov 03 @ 1:25 am
I now tested XP windows 98 compability mode enabled on the .exe and i couldn't get the gfx messed inside 2 minutes. I had try this fix on some 1.02 or something and it didn't work back then. So i guess a major improvement.
geposted Sat 15 Nov 03 @ 1:29 am
agreed, the program works just ok in xp mode UNTIL you start rapid scrolling or resizing desktop items...then the wave form will freeze for a few secs etc. in 98 emulation it is better. so not quite fixed.
geposted Sat 15 Nov 03 @ 2:15 am
