Forum: Addons
Topic: Midi Fighter Twister (Stems)
docb-djPRO InfinityMember since 2019
geposted Thu 30 Sep 21 @ 2:29 pm
MIDI Fighter Twister Hardware settings:
Bank 1 settings for all Encoders:
Has Dente = Yes
Sensitivity = Responsive
Indicator Type = Bar
Switch Action Type= CC Toggle
For colors, the "Off Color" is black for all encoders. "On Color" is set similar to VDJ color scheme (again, in the MF Utility).
See image for example:
geposted Thu 30 Sep 21 @ 5:39 pm
Major update:
Bank 1 is now set for Left/Right decks with all stems.
Bank 2 is now 4 Decks, 4 stems.
Bank 1 config:
Bank 2 Config:
geposted Mon 22 Nov 21 @ 7:29 pm
Thanks for this work.
Can you use the knobs as volume down and extra volume like when the stems are mapped to deck 3 and 4 on a controller?
Also, do you recommend using the mute_stem og stem_pad for the buttons?
geposted Mon 11 Apr 22 @ 11:32 am
Please help. I can't get to work at all. I'm on an M1 Macbook pro. It will not come off of the standard Twister mapping even though I followed the instructions. The original mapping doesn't work for me either, so that's also an issue.
geposted Wed 15 Feb 23 @ 2:13 am
