I would like to be able to see the normal tempo of the song on the decks... I know there is a percent difference on the tempo slider, and the current tempo but I would like to see the normal tempo of the song.
geposted Wed 06 Oct 21 @ 3:09 pm
get_bpm absolute
geposted Wed 06 Oct 21 @ 7:34 pm
Nicotux wrote :
get_bpm absolute
Is this a suggestion for me to modify the UI to add get_bpm absolute?
geposted Mon 11 Oct 21 @ 7:04 pm
that info is visible with pro skin and text on jog
geposted Mon 11 Oct 21 @ 7:22 pm
Ok, I am using the "Performance" layout and I see I have to show the jogwheel and the text on it to see that.
I would like it to be part of the UI without showing the jogwheel, but that is an alternative. Thanks.
geposted Tue 12 Oct 21 @ 9:48 am
That's exactly what locodog has highlighted. The deck shows original BPM. The jog shows the adjusted BPM.
geposted Tue 12 Oct 21 @ 4:53 pm
@groovin, he's probably using compact performance, so it needs a skin edit or using a custom button as an infobox
geposted Tue 12 Oct 21 @ 5:04 pm
