Doc says "<filelist source="automix|karaoke|sidelist|sampler"> : Provides the specific List of the Sideview (Automix, Karaoke, Sidelist and Sampler) without the top info bar and the bottom navigation buttons"
when this is true for "automix&karaoke&sidelist" this is not for "sampler" :
it opens a list with headers corresponding to those selected for virtual folder
in a way to get correct sampler you have to use "sampler://" syntax instead
which induce other folders can show as well - of course because of clones
some lists:// netsearch:// and other askthedj:// or localmusic:// are accessible as well
but they are case sensitive and need to be lowercase
taking "filters://" as an example : while accessible but empty, children are accessible
filters://Pictures.vdjfolder
as well as complex ones :
filters://By BPM.vdjfolder\(unknown).vdjfiltersubfolder
in fact would be fine vdj extension not to be necessary in these case
EDIT : Still problems with html entities in title ^^ : <filelist source="sampler"> not OK
geposted Mon 11 Oct 21 @ 6:22 am
