I've installed a few audio effect extensions, but am finding stability issues and strange audio effects. Is there anything i can do on my system to improve it? e.g. effects stay on after I turn off. Sounds goes to mono and stays mono for while after turning off effect.
geposted Fri 15 Oct 21 @ 10:53 am
Be more precise about the effects involved
(I have some ideas but may be totally wrong)
There can be many causes:
- Plugin was designed like that - strange ones, latency before to stop
- API change with old not updated effects (incompatibility) - most do not stop anymore or crash at start, some rare ones were creating multiple instances (may not exist anymore)
- Bug in plugin
some plugins are more or less known having some strange working mode
remember most are third party created and may be for a specific usage, not always matching general one
if they are not accurate simply forgot about them ;)
by the way you can rightclick the plugin in list and check "ignore"
- Bug in plugin
geposted Fri 15 Oct 21 @ 11:15 am
