I accidently loaded some corrupted files into the browser then deleted the folder. When I reloaded the same files that were not corrupted, the old corrupted files were still there. From the user manual I can see how to fix the database by using CONFIG>Browser but I can't find it in the settings menu.
Usually the database only needs a Fix - here are the steps:
1. Open the configuration dialog
2. Go to the Browser tab
3. Select the Drive from the drop-down
4. Click the ‗FIX‘ button
I need help
I need help
geposted Tue 19 Oct 21 @ 6:04 pm
what manual is that? looks like a v7 version
v8+ version, look at number 5 database>remove
http://www.virtualdj.com/manuals/virtualdj/interface/browser/toolbar.html
geposted Tue 19 Oct 21 @ 6:23 pm
Hello, can't find all my cues. I checked my data base on my system and it is still there but when I open VDJ it does not show. I usually use my Hard drive cos my songs are store there.
System: MacBook
System: MacBook
geposted Sat 07 Jan 23 @ 9:21 pm
