there used to be a plugin that enabled us to grab any of the 4 corners and warp the video output
it enabled us mobile DJs to reashape our video output so that if you had to place your projector in an awkward angle off to one side, you could adjust it to give a straight image on the wall.
this is gone now, since it was 32 bit only
so, im appealing for a 64bit version, pretty please... it was a great and very unique effect.
there doesnt seem to be any other software that can be used to in conjunction with VDJ to do this.
thankyou
thankyou
geposted Wed 17 Nov 21 @ 10:59 pm
I think you can do this with Tellyvisuals, newer versions.
geposted Thu 18 Nov 21 @ 5:43 am
@freppa you cant do it in those plugins i have tried.
what you can do in those plugins is you can drag between varying degrees of rectangular or square shape, but what im talking about is dragging the corners independently of each other so as to change the angle of the image.
or even just a dedicated horizontal & vertical keystone plugin would be perfect
geposted Sat 27 Nov 21 @ 4:00 pm
