Since many users also work with Soundswitch, it would be great if the "Soundswitch ID" from the mp3 tag can be displayed in the browser. or the filter shows which track has a "Soundswitch ID". for example like "Soundswitch ID exists yes / no"
geposted Wed 01 Dec 21 @ 1:23 pm
The "Soundswitch ID" is not a standard ID3V2 field (frame).
It's actually stored as a "user" field (frame) instead.
Probably it could be supported, but generally VirtualDJ supports only the standard ID3V2 fields (frames) and ignores the rest.
geposted Wed 01 Dec 21 @ 1:44 pm
Okay, that means it would be possible if I would ask the developers of VDJ very much :)
This little detail could definitely bring some new users to VDJ. ,)
geposted Wed 01 Dec 21 @ 1:51 pm
hallo
ich arbeite mit audiotragger kid 3 kann aber die sonudswitch_ID nicht finden
geposted Sun 10 Apr 22 @ 12:19 pm
I like the idea.
1+ from me!
1+ from me!
geposted Mon 11 Apr 22 @ 4:24 am
This may help, soundswitch autoscript creators.
When I add auto scripted tracks with soundswitch from Playlists, I recurse the playlist and then I use the tag editor to enter an SSTrax reference in either the comments, or one of the user fields ,
You can also change the name of these user fields to SStrax or whatever, if you like.
If you want more control over which tracks you autoscript , create a temporary playlist containing the track workload , autoscript them, enter the soundswitch data in the renamed user field. this is easier if the workload is kept in the same playlist
Remove the temp playlist afterwards , and use it again next time.
geposted Wed 23 Nov 22 @ 2:44 am
