I'm trying to set the first track of the transition as my default BPM. I use the variable BPM feature to set the BPM's accordingly. when I do this the last tracks BPM is tagged. this is not useful to me. please help! TIA
geposted Sun 05 Dec 21 @ 1:22 pm
It's not the "last" track used.
For tracks with variable BPM It's actually the part of the track with the greater length that's used to display BPM on Tag Editor and the Browser itself.
So, if your transition tracks have a 30 second section in the beginning to do the transition and then another good 2-3 minutes of the original song, it's obvious that the "second" section is far greater in length and thus has it's BPM used as the track's BPM value.
geposted Mon 06 Dec 21 @ 10:40 am
Thanks!
geposted Sun 16 Jan 22 @ 10:10 am
now there are the "remix points".
So if I look at such a mix with the "poi editor", then click on "show all points" there, I will find a few (or many) under "point type"
-----> Beat Anchor, Type: BeatGrid Anchor with the appropriate bpm for this section.
can't that be set differently for such songs with a beat change?
I mean automatically...
geposted Mon 17 Jan 22 @ 11:47 pm
