Hello all,
So I have Windows 7 64 bit and I've downloaded the Milkdrop 64 bit plugin for it and I still can't get it to work, VDJ 32 bit latest version.
I've followed every single post in these forums and I still can't get it to work, downloaded DX9, moved the files into the visualisations folder etc etc yet I'm still getting the 'incompatible' error.
I'm coming to the conclusion that because it's 32 bit VDJ it's not going to work.
Is there any way to download a 64bit VDJ that works on Windows 7 or can I find a 32 bit version of the Milkdrop plugin for 32 bit VDJ?
Is there something else that I'm missing?
Thanks all!
Thanks all!
geposted Mon 13 Dec 21 @ 6:24 am
your conclusion is correct. A 32 bit program won't host a 64 bit plugin.
x86 is still available
http://www.virtualdj.com/plugins/index.html?addonid=80785
geposted Mon 13 Dec 21 @ 6:41 am
Hello mate,
I've tried downloading the 32 bit version of milkdrop but the problem being is that it doesn't show up when searching within VDJ, typing milkdrop comes up with nothing.
Is there another way to get it?
Thanks man
Thanks man
geposted Mon 13 Dec 21 @ 7:02 am
extensions>effects>visualisations first result
geposted Mon 13 Dec 21 @ 7:08 am
Cheers man,
I'll check, I may have been checking the wrong bit.
geposted Mon 13 Dec 21 @ 7:14 am
Mate, nice one!
I'm bloody blind! Found it now!
geposted Mon 13 Dec 21 @ 7:21 am
I cant find it,is it still avaible?
geposted Wed 16 Feb 22 @ 5:49 pm
x86 version is still there.
geposted Wed 16 Feb 22 @ 6:06 pm
