Can I broadcast to Facebook Live and to Icecast at the same time?
geposted Thu 23 Dec 21 @ 10:07 pm
geposted Fri 24 Dec 21 @ 9:12 am
No need for third party software.
You can do video and audio broadcast at the same time from within VirtualDJ.
Just start one, then start the other.
geposted Fri 24 Dec 21 @ 9:32 am
Prism Live Studio do it
https://prismlive.com/
geposted Sat 25 Dec 21 @ 10:23 am
This sounds great Adion :)
Never seen any guide provided on the site about this before, but just found this page, could someone make a full guide for dual broadcast? https://www.virtualdj.com/wiki/videobroadcast.html
geposted Sat 25 Dec 21 @ 7:24 pm
Okay, so my radio station pays royalties but would I need to validate that through FB so they don't shut off my audio? see below:
Can I play copyrighted music on Facebook Live?
You can only play music on Facebook Live if you have the license for it. If Facebook thinks you're playing music on your broadcast that's protected by a copyright, Facebook will mute your audio. If you do this repeatedly, Facebook can delete your videos.
geposted Sat 25 Dec 21 @ 8:38 pm
or Twitch?
geposted Sat 25 Dec 21 @ 10:20 pm
Not much to say about it, select 'Video' then click 'Start Broadcast', then select 'Radio Server' and click 'Start Broadcast'. That's literally all that's needed.
geposted Sun 26 Dec 21 @ 5:32 am
okay, got Twitch going by adding the stream key in Broadcast. I love the VDJ graphic but it seems incompatible with editing in Twitch Studio - I can either use the stock graphics that VDJ provides but can't edit it or add a webcam or graphics of my own. Is this a limitation or is there a workaround?
geposted Sun 26 Dec 21 @ 5:37 am
Have a look in Extensions->Skins->Video Output. There are several layouts available to choose from, including some with dedicated space for web cam.
For example https://www.virtualdj.com/forums/235454/addons/Broadcaster_GFX_-_Disco_(Theme).html?page=1
For others you can just manually activate the 'Camera' plugin as effect, and use the camera options to position it where you want on the screen.
geposted Sun 26 Dec 21 @ 5:46 am
Adion wrote :
a little more detail on how to do that please?Have a look in Extensions->Skins->Video Output. There are several layouts available to choose from, including some with dedicated space for web cam.
geposted Mon 27 Dec 21 @ 2:29 am
This may inspire you:
Other detailed videos are linked in the video description
I also have a few other videos regarding broadcasting and video skins on my YT channel, so maybe have a look
geposted Mon 27 Dec 21 @ 7:51 am
this is very cool, the way you inserted yourself into the background - how can I do that?
geposted Mon 27 Dec 21 @ 5:26 pm
