Topic: Clock Countdown Plugin
What’s the difference between the 32 and 64 bit version and is there a countdown plugin for the 64 bit version. I have one but it only works for the 32…
If I need to go to the 32 bit for New Years so that I can use this plugin just need to be sure everything works the same way as the 64 which I’ve been using for awhile now.
geposted Mon 27 Dec 21 @ 6:41 pm
