I downloaded some of the pads plugins for the stems and I'm not sure how to activate them or view them. Once that's established that might fix my problem, but what I am trying to do is I'm using the sampler section of my controller eight pads to control the stems. I would like to assign one pad vocals only so I can have an acapella at the touch of a button rather than drop and deactivate four pads at once.
So hopefully either the plug-in I can use can do vocals only or is it possible that I can assign my own midi shortcut on the sampler pad just to activate vocals? Thanks
geposted Mon 03 Jan 22 @ 5:46 pm
Of course I figured out 5min after I posted this.
Sometimes that's all it takes to get the brain working.
geposted Mon 03 Jan 22 @ 11:28 pm
