Topic: Audio Settings Reset on Launch
Hi,
I am using the latest version of Virtual DJ Professional with a Pioneer DDJ-800 and each time I launch VDJ there is a bit of a hang upon launch and when I then look at my audio settings they have reset to the default input/output for my controller. This is not what I want as I am sending a single master out to OBS Studio for my stream.
I've tried creating separate profiles and no matter what I do the same thing occurs every time on launch, all of the default DDJ settings return. It will keep my settings if I keep the controller turned off, so there is something about it being turned on that is making this occur.
Is there any way to prevent this from occurring?
geposted Sun 09 Jan 22 @ 8:02 pm
there is a setting under options called 'audioAutoDetect', you could try setting it to 'no'
Pete
geposted Sun 09 Jan 22 @ 11:19 pm
I appreciate the response but it had no effect. I believe that setting is tied to the recording option that doesn't start unless audio is detected.
Does anyone from VirtualDJ support read this forum? How do I file a bug with their engineering team?
geposted Mon 10 Jan 22 @ 3:44 am
locodogPRO InfinityModeratorMember since 2013
The dev team read all the forums.
geposted Mon 10 Jan 22 @ 3:48 am
The record audio detect is 'recordWaitForSound'.
I know some users who had this similar issue and changeing the 'autoAudioDetect' fixed it.
So no idea what to suggest now, looks like one for the devs.
geposted Mon 10 Jan 22 @ 12:22 pm
Yeah, I confirmed again my hovering my mouse over the setting. If the DDJ-800 is powered off the setting works, but even after deleting all the profiles, if I power back on the DDJ-800 the default settings load again and my setting are overwritten.
geposted Mon 10 Jan 22 @ 5:24 pm
Bump. Anyone from VDJ engineering able to respond? It's been two days.
geposted Tue 11 Jan 22 @ 8:23 pm
Can you post a screenshot of the Audio setup that you manually set, and another one showing what VDJ auto applies ?
geposted Tue 11 Jan 22 @ 9:38 pm
First image shows the proper setting (DDJ-800 is not powered on at this point), second shows what happens when DDJ-800 is powered on, and third shows what I see if I close VDJ and reopen with DDJ-800 powered on.
geposted Wed 12 Jan 22 @ 8:21 pm
I should add that despite the config name showing differently after powering on the controller, switching to the other config does nothing. It still shows all of the same inputs and outputs.
geposted Wed 12 Jan 22 @ 11:03 pm
Bump for visibility. Still waiting for a VDJ dev to acknowledge.
geposted Sun 16 Jan 22 @ 1:39 pm
I'm not sure what would automatically change the config.
You'd have to press the 'Use Soundcard' button on the detection window, the controller button in the audio config, or select a different profile manually for it to change normally.
geposted Sun 16 Jan 22 @ 1:51 pm
I'm doing none of those things. Also, if the controller goes to sleep a similar thing happens when I wake it.
geposted Sun 16 Jan 22 @ 10:43 pm
And since there is no official support here, I'm continuing to try and find a solution myself. If I open the audio settings, VDJ will not overwrite my saved settings.
geposted Tue 18 Jan 22 @ 5:14 am
No official support .... 2 posts aboce yours Adion is CTO and lead developer.
geposted Tue 18 Jan 22 @ 8:17 am
Just took a look at the mapping files, and indeed VDJ will force the default audio setup on startup based on the DDJ-800 Mic mode (hardware or software).
You can remove this force, by just editing the ONINIT key of the DDJ-800 mapping.
Delete the last part of the action and leave only the following ..
ONINIT key :
fake_master on & fake_hp on & fake_hpmix on & deck all filter_activate off
geposted Tue 18 Jan 22 @ 9:10 am
ONINIT key :
That did it! Thank you very much!
geposted Tue 18 Jan 22 @ 5:24 pm
