Topic: Back to vdj
good morning to all.
Back to vdj, i would appreciate the help from the community.
My set up
a/h db4 mixer
rane 12's mk2 pair
need your help to get the ball rolling...
When i plug in the mixer it is regnize by the software....
The db4 does not have a set up manual four audio.
Would someone be kind enough to guide me with the best set up possible.
Iwish to use my set uo both in dvs and hid mode.
Thanks for your feedback
geposted Tue 11 Jan 22 @ 3:13 pm
Start by installing the drivers for the mixer
https://www.allen-heath.com/ahproducts/xonedb4/
I didnt try this mixer myself, but looks like it might have audio built in.
If so you should be able to select in as audio out in VirtualDJ.
And use the source select on the mixer to USB or PC or similar
geposted Tue 25 Jan 22 @ 5:55 pm
