I am running the latest version of Soundswitch (2.5.1.424) and the latest version of VDJ (8.5-64 b6800). I have VDJ set to use os2l (set to auto). I have disabled the Windows firewall completely to avoid those issues. I o not have any folders on Onedrive at all. Virtual DJ seems to operate just fine. Soundswitch also operates just fine. In Edit mode in Soundswitch, I can see the VirtualDJ folders. However, in Performance mode, the indicator at the top of the screen shows Virtual DJ as greyed out. When I play tracks in VDJ, the lights do not react as scripted in Soundswitch. What else can I try to get the two applications to talk to each other?
geposted Thu 20 Jan 22 @ 9:17 pm
Hi ... I was searching for something else and came across your post. inside VirtualDJ, open the DMX tab and select any function. Sometimes this is needed to "wake up" Soundswitch from within VDJ. Hope this helps ...
geposted Thu 03 Mar 22 @ 7:01 am
when in Windows, disable the firewall (Defender or external), that worked for me.
I couldn´t make the connection betwenn VDJ/SS workin with enabled firewall.
geposted Thu 13 Jul 23 @ 1:52 pm
