Will this work with VDJ 2021:
geposted Fri 21 Jan 22 @ 12:57 am
Anyone...Bueller? Bueller?
geposted Sun 23 Jan 22 @ 3:20 am
it should work
geposted Sun 23 Jan 22 @ 3:32 am
Have you used that app?
Opinions?
Opinions?
geposted Mon 24 Jan 22 @ 6:28 pm
You can also do it manually with any text editor. Open up the files and batch replace the file location.
geposted Mon 24 Jan 22 @ 6:31 pm
Tried that, did not work.
geposted Mon 24 Jan 22 @ 6:33 pm
That tool is half a decade old. Probably not necessary ...
VirtualDJ is good at automatically "fixing" playlists if its just a drive letter change.
Or you can start using VirutalFolders ("smarter" playlists) that are database driven, and 'agnostic' to drive letter
geposted Tue 25 Jan 22 @ 5:08 pm
And if it didnt work, perhaps the change is more than just a drive letter? New path, renamed path, or moved files? You can open any of the "missing file entries" in your playlist, in the Tag editor, and see where VirtualDJ expects it to be
geposted Tue 25 Jan 22 @ 5:10 pm
Rune,
You were correct.
The old history had a space in the directory name I was not accounting for.
Thanks for the response.
You were correct.
geposted Fri 28 Jan 22 @ 1:44 am
